12V conversion
Mike
07-04-2003 16:39:33
Why does the schematic for the 12volt conversion show re-using the 6 volt coil. I would think I would be better served with a 12 volt coil.
kevin
07-04-2003 19:31:31
 Re: 12V conversion in reply to Mike, 07-04-2003 16:39:33
Most coils are 6 volt. That is why we need a ballast resistor. The resistor is in series with the coil to provide 6 volts while running. When you crank, the resistor is bypassed sending 12 volts to the 6 volt coil. This results in a very hot spark for easy starting. I hooked mine up in this fashion, and the silly thing starts better than my car.
