Year of a TO-35
AGEN
01-05-2000 16:58:58
Can anyone tell me the year a TO-35 with serial number 131733 was produced. I am not sure whether it is a Massey-Ferguson or a Harry Ferguson tractor. If anyone knows the year, I would appreciate your help. Thank you.
Brian
01-06-2000 18:01:08
 Re: year of a TO-35 in reply to AGEN, 01-05-2000 16:58:58
Looking at your serial number suggests it is a T0-30. If you look on your serial number plate and it just says TO and then the serial, number your tractor is a TO 30 most TO35's the serial number plate will say TO35 ther a serial number. If you look at the number that is cast in to the steering column it will start out as TO35XXX, this number is the factory part number for that part. If you look at other parts on your tractor you will notic that they all start with the TO designation. I hope this info helps out.
Good luck
Brian
Jim Duncan
01-05-2000 23:06:02
Without further information (engine type and number) your tractor could be a couple of different years/models. Are you sure that it is a TO-35? The serial number suggests that it is probably a TO-30 built late in 1954. The serial numbers are of course consecutive, and the chart I am using indicates that the TO-30's built in 1954 ran from serial number 125929 through 140000.
Try visiting this website: www.geocities.com/MotorCity/Downs/9828/hf_02e.htm
for more info.
AGEN
01-06-2000 15:53:53
 Re: Re: year of a TO-35 in reply to Jim Duncan, 01-05-2000 23:06:02
Thanks, Mr. Duncan, I appreciate it.
