Front Wheel Bearings
Clint
07-22-2003 07:39:43
Question may be a little basic, but I have a TO-20 and I am need of replacing the front wheel bearings, the book makes it seem as if they are pressed in, are they ?? And what is the correct procedure in accessing and replacing the bearings?
Any help would be appreciated.
john(UK)
07-22-2003 11:09:22
 Re: Front Wheel Bearings in reply to Clint, 07-22-2003 07:39:43
The bearings fit just like any other wheel bearing you come across, they are pressed in but not by a press if you get what I mean. they are quite easy to replace no special tools required.
Clint
07-22-2003 11:13:35
 Re: Re: Front Wheel Bearings in reply to john(UK), 07-22-2003 11:09:22
Thanks for the reply, and I do know what you mean as far as being pressed in is concerned, any suugestions on how to get the center hub cap off in order to expose the castle nut. I have been halted there
john(UK)
07-22-2003 11:23:54
 Re: Re: Re: Front Wheel Bearings in reply to Clint, 07-22-2003 11:13:35
well it should just unscrew in normal fashion and the nut lies underneath as you know. I am puzzled why you say that about the hub cap, unless it has been changed for something non-standard I would have thought it was obvious, sorry maybe its me.
