TO30
NEIL WI
07-27-2003 05:42:07
The hand throtle on my to30 keeps working up when running the tractor. Anyone have any suggestions for a quick fix. thanks
rod
07-27-2003 06:43:06
 Re: TO30 in reply to NEIL WI, 07-27-2003 05:42:07
the fibre disc that makes it stay in place wears out I think Ford N's have same set up maybe a new one would work also there is a spring and a jam nut on the shaft you can try tightening it up I have used wire screening to make a disc or you could glue two piesces of emery cloth to make one semd me an email and I will send you a parts scan of the whole set up.
regards
rod
