electrical problem
bill
07-27-2003 12:48:52
after putting a battery in a to30,52mod. 6 vol. volt meeter shows neg.charge. all i done was change the battery nothing else.was showing a pos charge on old battery. any suggestions , thank you
danct
07-27-2003 20:09:40
 Re: electrical problem in reply to bill, 07-27-2003 12:48:52
if its like mine Pos goes to ground which is the frame of the tractor and Neg goes to starter sw,put old batt beside new one and compare that the terminals are connected same as they were ,good luck
Bill
08-01-2003 20:02:06
 Re: Re: electrical problem in reply to danct, 07-27-2003 20:09:40
That was the problem thanks for your info.
jeff
07-27-2003 12:55:42
did you connect the battery cables up the same as they were on the old battery,both ends of the cables
