Whats is Polarization
Barry Reid Stir
07-28-2003 12:14:16
Like the subject says, and I dont want to come off sounding like a complete dummy here, but just what the heck is polarization mean. Thanks Barry
danct
07-28-2003 18:29:39
 Re: Whats is Polarization in reply to Barry Reid Stirling Ontar, 07-28-2003 12:14:16
Barry
having just rewired my t30 i think i can explain,the generator must be repolarized to make sure it has the correct polarity with respect to the battery ,there are two wires coming from the generator the F terminal connects to F on the voltage regulator, the A terminal connects to the GEN terminal on the regulator now before you start the engine connect a jumper wire from the A terminal of the generator to the Negative side of the battery just hold it for a second you will see a spark but what you are doing is telling the generator to charge correctly for the way you are wired,it worked for me so good luck
Barry in Ontario
07-29-2003 05:02:01
 Re: Re: Whats is Polarization in reply to danct, 07-28-2003 18:29:39
Thanks danct
That makes perfect sense to me now.
