hydraulic take off
nick
08-11-2003 10:43:45
Hi,
anyone have a schematic or photo of a TEA 20 with hydraulic lines (for the front loader)fitted. Is it true that the output line is from the front right of the alloy plate, that sits under the transmission.
john(UK)
08-11-2003 10:56:58
 Re: hydraulic take off in reply to nick, 08-11-2003 10:43:45
There are two take off points on the pump base at diagonally opposing corners, the rea one is usually used for the trailer tipping pipe but it can be used for anything you like the front one is usually used for loaders. When screwing any adaptor in the pump base, make sure its the correct thread and do not over tighten if it leaks or you may strip the pump body. Use new sealing washers everytime, ignore this at your peril.
