Tea-20 engine rebuild/ refresh
Morty-Alberta
08-21-2003 12:40:26
What sort of engine rebuild can I do with the engine still in the frame, I think I lost a valve on the weekend and figure that I should do something on the engine too- rings/liners/ big end bearings. but I don't want to split the tractor as I don't have a shop only dirt and I can't afford too much- this is one with the standard engine
Jim W
08-21-2003 13:40:28
 Re: Tea-20 engine rebuild/ refresh in reply to Morty-Alberta, 08-21-2003 12:40:26
You could do the rings, liners, big end bearings, crankshaft thrust washers, and the centre crank bearing (only). You will have to work around the crankshaft being in the way but the pistons with rods do come out the top, and so do the liners.
The "figure 8" gaskets will need to be replaced (that seat between the liner and the block) as well.
If you don't want to spend too much, you might not want to consider doing the liners. I think you can only get liners and pistons as a kit for something like $600 US.
Regards,
Jim W
