TO-30 Spark
Pat
08-25-2003 07:00:25
I have spark at the points but none at the plug. I've replaced the rotor as it had corrosion. The cap looks good as do the wires. What should I be looking for here? New coil or condenser?
This is really dumb but.... is # 4 cylinder closest to the operator or the radiator? (I marked the plug wires a year ago and did not mark the engine when it was taken apart.)
Thanks.
Pat
08-25-2003 11:36:48
 Re: TO-30 Spark in reply to Pat, 08-25-2003 07:00:25
Thank you for the advice. I'm sure glad I asked about the cylinders... I had them backwards. (Figures).
Jerry/MT
08-25-2003 10:38:31
Pat:
Check to make sure that the spring contact on the rotor makes contact with the center terminal "button" on the distributor cap. If it doesn't, bend it up so that it does. Also make sure that the rotor tip is clean by filing with a point file. The #4 cylinder is nearest the operator position. It's 1-2-3-4 from front to back.
Hope this helps.
