TE-20 Clutch
Olly Richman
08-29-2003 11:03:19
Hi,
I have just been given a 1947 TE-20 (Z120- Engine) and I am having trouble with the clutch sticking. It doesn't slip but it takes a while to engage/Disengage. Can anyone help?
Thanks,
Olly.
Jerry/MT
08-29-2003 13:29:54
 Re: TE-20 Clutch in reply to Olly Richman, 08-29-2003 11:03:19
Olly:
Have you tried adjusting the free play in the clutch pedal?
john(UK)
08-29-2003 14:11:35
 Re: Re: TE-20 Clutch in reply to Jerry/MT, 08-29-2003 13:29:54
Check that there is clearance in clutch pedal, you should have 1/2" between the pedal the the underside of the footrest (not running boards if you have them fitted but the original pedal)If the clearance is there and it still does it, you may have one of the following situations. 1. The clutch disc is worn and it is down to the rivets and they are slipping on the flywheel or clutch pressure plate (usually the clutch pressure side)
2. The clutch plate is sticking on the drive shaft into the gearbox, you will need to remove the engine to free-off the plate.
