What Size Battery Cables
Barry Reid, Sti
09-08-2003 11:48:30
Afternoon Everyone. I replaced the battery cables on my TEA-20 a few weeks back and noticed that the tractor takes a bit longer to roll over now. The battery is brand new. Can anyone tell me what gauge of cable I need.I think I may have the wrong ones on. Thanks ,,, Barry
marlowe
09-08-2003 13:45:38
 Re: What Size Battery Cables in reply to Barry Reid, Stirling Onta, 09-08-2003 11:48:30
at least 0
Ray,IN
09-08-2003 21:42:42
 Re: Re: What Size Battery Cables in reply to marlowe, 09-08-2003 13:45:38
The original cables are "O" gauge. Number 2 gauge cables will suffice if you keep the connections clean and tight. The wimpy 6ga cables made for 12v systems will NOT carry sufficient current in a 6v system. I found on my TO30 that the ground (+) cable had very high resistance, this turned out to be in the bolt connections between the cable and the engine block. There are 4 bolt connections(castings and sheet metal) between the starter and the ground cable itself. I installed a longer + cable and attached it to a starter mounting bolt, this resulted in great starting.(Got the idea from an old Case diesel tractor configuration) The 6v battery really spins the starter in freezing weather. I reinstall an original when showing though.
09-09-2003 04:29:03
 Re: Re: Re: What Size Battery Cables in reply to Ray,IN, 09-08-2003 21:42:42
Just one more comment if I may. My TEA-20 has been converted to 12 volt,so saying that would the gauge still be the same as 6 volt?? Thanks for your input Ray and Marlowe
marlowe
09-09-2003 19:14:08
 Re: Re: Re: Re: What Size Battery Cables in reply to Barry Reid, Stirling Onta, 09-09-2003 04:29:03
well with that said you better look at some thing other than cable size ?with 12v you don't need 0 4or 6 will work just fine must be some thing else
john(UK)
09-10-2003 16:33:43
 Re: Re: Re: Re: Re: What Size Battery Cables in reply to marlowe, 09-09-2003 19:14:08
you might like to try the starter switch on the top of the clutch housing under the battery. You can adjust it but the contacts could be burned.
