Over riding clutch problem
Old professor
09-15-2003 14:53:13
Just bought an O>R>C> for 1951 TO 20 but the clutch wont slide on 1 1/8 shaft far enough
to allow me to install drive pin/spring pin in hole in shaft. Can anyone help? Has anybody else had this problem?
RP
09-15-2003 18:36:36
 Re: Over riding clutch problem in reply to Old professor, 09-15-2003 14:53:13
Yeah, I had that on my '51 TO-20 also.
In my case the PTO shaft had various burrs, dings, etc. in the splines and that's what held it up. A little work with a file fixed it right up. Actually it was an old ORC and I had the same problem getting the brush-hog attachd to the ORC (same fix)!
Once you finally get it on there and run it a little it'll wear in just fine.
old professor
09-15-2003 20:12:47
 Re: Re: Over riding clutch problem in reply to RP, 09-15-2003 18:36:36
Thanks for your comments RP but the end of the ORC
hits the bearing and snap ring back on the shaft
before the holes line up. Will the pto shaft move out any ?
RP
09-16-2003 14:09:05
 Re: Re: Re: Over riding clutch problem in reply to old professor, 09-15-2003 20:12:47
I don't think they're supposed moved in or out at all! As I recall my PTO sticks out about 3 or 4". Any chance someone twisted yours off and redrilled a new hole in it?
Anyone else have any thoughts on this?
Paul (FLA)
09-17-2003 05:01:19
 Re: Re: Re: Re: Over riding clutch problem in reply to RP, 09-16-2003 14:09:05
My overriding clutch slides into the holder for the PTO shaft. (just like the dust cap does)There is an overlap of approx 1.2 to 3/4 inch. Could this be the problem?
