Front tire mounting question
Steve
09-16-2003 21:25:07
I managed to find a pair of used "old style" three ridge tires (6.00x16) to put on the front of my TO-20. I cleaned up the original rims and took the tires in to the local tire place one at a time as I got the rims cleaned up. I bought new tubes from Gemplers. When the guy mounted the first tire he used some sort of rubber/plastic bushing (like a grommet) around the valve stem where it came through the rim. When they mounted the second tire (a different guy did it) they didn't use a bushing, and I've got about a 1/2" valve stem sticking through a 5/8" hole in the rim. Do I care about this. Will it be detrimental to the life of the tube in the tire? Should I take the second tire back to be remounted with a bushing? Thanks for your help.
Barry Reid, Stirling Onta
09-22-2003 04:46:58
 Re: Front tire mounting question in reply to Steve, 09-16-2003 21:25:07
Morning Steve
Any TSC Hardware store here in Canada can get the old tires that you are talking about. I got mine there and they were brand new cost was $85 canadian. just my 2 cents worth
To-35Man
09-17-2003 02:52:09
I've seen them both ways with and without...unless the valve stem hole is rusty or jagged I'd say don't worry about it....there again you sound like me a stickler for detail if you are carry it back...I would
