How to test for type of transmission oil in TO-20?
Tree Farmer
09-26-2003 08:48:58
I have to add oil to the transmission, etc., and after reading on this board, learned that it should be mineral oil. Any ideas on how I can find out what type oil is currently in the transmission? Smell? Taste? I planned to add mineral oil, but if the existing is petroleum based type , thought it might not mix. Thanks for any advice.
Jeff-Oh
09-26-2003 09:21:46
 Re: How to test for type of transmission oil in TO in reply to Tree Farmer, 09-26-2003 08:48:58
Why not take this opertunity to change the oil? It is a six gallon system so you are looking at $35 to $45 in oil but then you would know for sure. This is offset by the amount you need to add anyway. You can also take this time to clean the system out.
Just a thought.
Jeff
Tree Farmer
09-26-2003 17:32:40
 Re: Re: How to test for type of transmission oil i in reply to Jeff-Oh, 09-26-2003 09:21:46
Thanks Jeff-Oh. I never thought of that - good idea.
Steve
09-26-2003 11:44:31
I've been planning to change mine too, for a similar reason - I have no idea what's in there now. Say I do this in the next few weeks - I've been thinking about it all summer. Do I need to run the tractor up and down the lane first to loosen up the sludge, or should I do it when its been standing for a while? I assume it should be done before it gets much cooler here in Delaware.
marlowe
09-26-2003 12:31:47
 Re: Re: Re: How to test for type of transmission o in reply to Steve, 09-26-2003 11:44:31
best is to work it so it is hot and it will drain better and some of the dirt will go with the oil. you chang engine oil hot so why not the trans?
