Fferguson TO-30
Tony
11-04-2003 17:25:40
hello everyone
I am having a problem with the hydraulics on my tractor, when I go to let It down It slams to the ground, it Is hard to let It down easy, any and all help on this problem Is appreciated.
Thank you Tony
Jerry/MT
11-06-2003 08:51:37
 Re: Fferguson TO-30 in reply to Tony, 11-04-2003 17:25:40
When I lower an implement on my TO-30, I position the control lever partway down and it doesn't "crash" to the ground. If I place the lever in the full down position quickly, it will fall quickly. It will fall faster with heavier loads. Try moving the control lever to a position between neutral and full down and see if that helps.
Phil(va)
11-05-2003 07:29:53
On the Ferguson 20 and 30, your hydraulics do not have position control and your lift will naturally be either up or down with no "feathering" capability unless you install a Zane Thang or Fergie Postioner or comparable device. Check the archives for more on those items. If you are lowering with an implement attached it will naturally fall rather quickly without position control.
