to-30 can't believe
james
11-08-2003 03:32:22
i can't believe i seem to be the only person having cold weather hydraulic problems(slow to lift)(fine when weather is warm to hot) with my to-30 ferguson in cold weather below freezing using what is recomened 80-90 mineral oil. what can i use in the line of lower weight oil and still be ok in warm to hot weather
Ray,IN
11-09-2003 14:07:13
 Re: to-30 can't believe in reply to james, 11-08-2003 03:32:22
Many use 40 wt/ mineral oil in winter with no harm. Be sure to change back to 90wt next spring though.
toolman
11-08-2003 12:15:55
i live in canada so i don,t know if you can get this stiff where you are but, i use durtran tractor and tranmission hydrulic oil, i use it year round and don,t have any problems, i have used it for years, i have checked it in comparison to the recommended 80/90 mineral oil meets or exceeds everything only one draw back i guess would be the cost i paid this year with taxes 63 bucks for all i needed, but if you can keep out the moisture it last s a long time,the inside of my tractor was nice an clean no sludge build,works great,petrocan makes this do a search on it.when it gets really cold minus 20 or more i don,t run the old girl anyways .
Jerry/MT
11-08-2003 10:39:45
I live in Western Montana and yesterday I went out at 3F, started my tractor and the transmission/hydraulic oil was so cold that I couldn't take my foot of the clutch without killing the engine. After about 10 minutes of warming up, I was able to release the clutch and drive off. The lift was slow, but after driving around for about 5 minutes, it was fine. It's just something you have to learnto live with.
Scott
11-08-2003 06:03:53
Hi James
My dad always put 1 quart of diesel fuel in the tranny for the winter no it won't hurt. This will also help with sticky valves this tip is from a 83 year old ferguson dealer. Good luck Scott
Paul in Ms
11-08-2003 04:54:11
Have you thought about a magnetic oil pan heater on the transmission sump area. Works great for engines in cold weather.
Randy
11-08-2003 18:42:40
 Re: Re: to-30 can't believe in reply to Paul in Ms, 11-08-2003 04:54:11
You can get the magnetic heaters from Wolverine products. Do a search on the net.
marlowe
11-08-2003 04:53:24
this is common in cold weather they all do it just let it warm up a little. going out to cut wood at 5 above and my to-20 is running as we speak to warm up
Alvin n Ms.
11-08-2003 05:38:10
 Re: Re: to-30 can't believe in reply to marlowe, 11-08-2003 04:53:24
I remember some of the old operators manuals, sugesting that a quart of kerosine be added in winter to thin the oil. What would it hurt? I dont know.
bob
11-08-2003 15:28:18
 Re: Re: Re: to-30 can't believe in reply to Alvin n Ms., 11-08-2003 05:38:10
This is probably OK if you change your oil in the spring. Do it too many years in a row and you'll have a lot of kerosene in the system.
