'51 TO-20 Quickly Overheats, HELP ME!
bartfish
11-09-2003 22:32:36
My TO-20 recently just quickly overheated in less than 10 minutes. Over the last winter I replaced the head gasket and thermostat, and gave it a new paint job. Long story short I was running it the other day and it quickly overheated, it shot from below normal to overheating in less than a minute. Is this a warped head? I also heard a low growling sound from the tractor, like metal quickly expanding? Please help, I love my fergie so much!!!! Thanks in advance.
mac
11-13-2003 16:33:38
 Re: '51 TO-20 Quickly Overheats, HELP ME! in reply to bartfish, 11-09-2003 22:32:36
Not to be a smart --- but when you overhauled the engine you did,ent happen to put the thermostat in backwords did you.
TO24424
11-12-2003 16:40:09
I believe you said that you just replaced the head gasket. Are you sure you put it on "right side up" ? I do know that with the standard engine, you will partially clog a coolant passage if the gasket is installed up.side. down.
Tex Ferguson
11-11-2003 18:25:58
Hey Mr. Bartfish, I don't think anybody mentioned that delayed ignition timing can cause overheating, since the fuel-air mix is still burning on the way out the exhaust valve; that might be a last-resort thing to check. There was a post here a month ago about the exhaust manifold glowing cherry-red from this cause. Also, having no thermostat at all might cause coolant to pass through the radiator too quickly to dissipate its heat load -- happened to me with a '78 Ford car.
Good luck! Tex
TO24424
11-11-2003 17:10:33
Top and bottom radiator hose should be about the same temperature...if not...thermostat for sure.Be sure to "burp" the cooling system. I'ts not common with a cooling system this simple, but the're could be an air pocket somewhere. Let it get warm/ hot, shut it off, wait a few minuets and repeat. Good luck, have fun...
john(UK)
11-10-2003 16:04:04
The noise you mentioned, just wondering if it was pressurising the system due to head gasket blown or a cracked head or cylinder block. Did you try taking the radiator cap off when this happened? If you do this be careful you dont scald yourself, release the pressure slowly and use a large cloth to open the cap.
bartfish
11-11-2003 13:41:38
 Re: Re: '51 TO-20 Quickly Overheats, HELP ME! in reply to john(UK), 11-10-2003 16:04:04
No, I never took the radiator cap off, I was afraid of getting burned. Everything appears ok, except the thermostat, which I haven't had time to check. One other thing I noticed when it happened is that the engine block was extremely hot. Thanks for all the replies.
john(UK)
11-11-2003 15:25:04
 Re: Re: Re: '51 TO-20 Quickly Overheats, HELP ME! in reply to bartfish, 11-11-2003 13:41:38
Well try removing the thermostat, see if that stops the overheating. Maybe something as simple as that, let's hope so. We used to have quite a bit of trouble with that thermostat in the top hose, dont know why we should though, Has the tractor had a bump on the front and its pushed the radiator back slightly and damaged the top hose with the thermostat inside?
Jerry/MT
11-10-2003 11:23:28
Obviously make sure that you have sufficient collant in the radiator. Make sure the radiator is clear of debris. Make sure the fan belt has the proper tension, and that the thermostat is working.
RP
11-10-2003 14:38:59
 Re: Re: '51 TO-20 Quickly Overheats, HELP ME! in reply to Jerry/MT, 11-10-2003 11:23:28
and that the exhaust isn't plugged up from backing into something...
David UK
11-14-2003 06:38:36
 Re: Re: Re: '51 TO-20 Quickly Overheats, HELP ME! in reply to RP, 11-10-2003 14:38:59
I'd run it cold with radiator cap off and look for bubbles to check if head gasket is leaking or for cracks clyinder to water jacket. If no bubbles then I'd do easy stuff first like checking thermostat. Is water pump ok? I have had ones on cars with impellor worn away. Interested to know cause. We all learn from these problems.
