3-point leak
Mike Kenyon
11-11-2003 11:26:36
I have a Ferguson TE20 that is leaking fluid from around the stationary pin on the housing where the 3-point arm pivots. I've removed the arm and the nut that holds a cover plate. The pin can move around but won't come out. Would like some advise. Thanks...
john(UK)
11-11-2003 13:42:10
 Re: 3-point leak in reply to Mike Kenyon, 11-11-2003 11:26:36
You will have to remove the Axle trumpet housing to tighten the nut AND replace the gasket under the plate. If you would like a page from the parts list to show you whats under there...send me an email address I can send it too.
Mike Kenyon
11-12-2003 04:50:43
 Re: Re: 3-point leak in reply to john(UK), 11-11-2003 13:42:10
Thank you for the reply and yes I would like the page from the parts list.
john(UK)
11-12-2003 11:09:26
 Re: Re: Re: 3-point leak in reply to Mike Kenyon, 11-12-2003 04:50:43
Hi Mike, Sorry but I need an email address to send it to.
Mike Kenyon
11-12-2003 11:19:09
 Re: Re: Re: Re: 3-point leak in reply to john(UK), 11-12-2003 11:09:26
I'm sorry I through it show up when it is posted.Anyway here it is mikekenyon@wright-products.com Thanks talk to you later
