HYDRAULICS
PETE
11-16-2003 11:39:26
ARE THE HYDRAULICS ON THE TO 2O AND ON LIVE OR ARE THEY LIKE THE ONES ON THE FORD 9,2 AND 8N TRACTORS?
ZANE
11-24-2003 05:02:32
 Re: HYDRAULICS in reply to PETE , 11-16-2003 11:39:26
You can have both position control and live hydraulics on this tractor using my add on devices.
See the link below.
Phil(va)
11-16-2003 15:22:27
As Jim says, they are not live. If you depress the clutch, the lift will not raise. However, the 8N is better in one regard than any of the other tractors you mention, including the TO20 in that it has position control, which the others don't, unless modified.
PETE
11-16-2003 18:09:37
 Re: Re: HYDRAULICS in reply to Phil(va), 11-16-2003 15:22:27
PHIL(VA) WHEN YOU SAY THEY DONT HAVE POSSION CONTROL, DO YOU MEAN ALL UP OR ALL DOWN OR DO YOU MEAN THEY LACK DRAFT CONTROL? AND WHAT ABOUT THE MODEL 35? THANKS FOR INFO
Phil(va)
11-19-2003 18:57:27
 Re: Re: Re: HYDRAULICS in reply to PETE , 11-16-2003 18:09:37
I think you got all your questions answered except not sure if anyone answered your question on the 35. Yes, the 35 (both TO and MF) have position control. They were the first Fergusons with position control from factory. As someone else said, they ALL have draft control. Hope that helps.
Jeff
11-17-2003 08:12:56
The Fergusens all have Draft control. What he means is that they do not have position control. Position control comes into play when using a mower. You can set the lift to any position you want. It is not an all up or down as you suggested. However, as you operate the mower can change heights due to not being able to exactly set the controller to dead nuts neutral.
What position control does is, it provides a feedback loop in the controls so that after you set the position, if the lift drops the controller is pulled up lifting the arms to the initial setting. Also if the arms go to high then the controller is pushed down dropping the arms to the initial setting.
Zane Sherman and an Austraian Co. both have add-on products to provide position control.
Jeff
norbert kanzler
11-17-2003 14:53:26
 Re: Re: Re: Re: HYDRAULICS in reply to Jeff, 11-17-2003 08:12:56
I am very interested in the Australian Company that has position control for old 9N and ferguson tractors can you please email me more information on this company?
Jim
11-21-2003 03:24:31
 Re: Re: Re: Re: Re: HYDRAULICS in reply to norbert kanzler, 11-17-2003 14:53:26
Here is another place to get the position control. This one is in the U.S.A. Jim
http://hometown.aol.com/wzsherman/myhomepage/sale.html
john(UK)
11-18-2003 12:14:52
The Fergy Positioner is done by a guy named John Gaunt. Sorry I cant tell you anymore than that at this time, I just checked and the site is down, if you need more information post again and I will get it for you.
Jim W
11-18-2003 13:52:07
 Re: Re: Re: Re: Re: Re: HYDRAULICS in reply to john(UK), 11-18-2003 12:14:52
Check this UK site
Jim W
11-18-2003 13:54:30
 Re: Re: Re: Re: Re: Re: Re: HYDRAULICS in reply to Jim W, 11-18-2003 13:52:07
I will try this again
Jim W
11-16-2003 14:25:11
They're like the Ford series.
Jim
