'51 TO20
paul ferguson
11-17-2003 13:56:00
HEllo, I removed my hydraulic pump from my tractor last month(turned out to be a totally diff problem, so my pum is ok). Since it is out ,and who knows when if ever it has been gone through, I would like to replace the gaskets,seals, etc that I may need to, and give it a good once over and good cleaning..Where can I get parts and a good diagram of this..Thanks again..Paul
john(UK)
11-18-2003 11:39:35
 Re: '51 TO20 in reply to paul ferguson, 11-17-2003 13:56:00
I can send you the page from the parts list if you wish. I will need an email address to send it to though. Parts are available on this site, go to near top of page and click on "Ferguson parts" or you can get Sparex parts from your local dealer.Most things are available though
Jim W
11-17-2003 19:48:17
Here's a picture. Once you have it apart it is fairly obvious how it all works and goes together. If I remember right the thickness of the "head gaskets" is citical so make sure you get the right ones - they changed thickness somewhere in the production run (I think...)
Jim
Ray,IN
11-17-2003 19:41:30
I knew I should've kept that link. Several months ago someone posted a link to an exploded diagram of the pump, and I think, info on where to buy the rebuild kit. Hopefully a search will discover it. Do the YT sponsors listed under "marketplace" have the parts or kit?
p ferguson
11-17-2003 20:04:22
 Re: Re: '51 TO20 in reply to Ray,IN, 11-17-2003 19:41:30
Hi guys thanks for the info...Jim I could not open the link..said page was unavailable...Thanks
