2085 lacks power
glen (ontario)
11-17-2003 15:06:10
There has been lots of discution on this I am a bit of a rockie so i will throw it out to you guys . tractor starts no problem and after it warms up it will run with out chocking it is this normal in cold weather .fuel flow seams to be ok ,Is there a way of checking if I have enough ,there is still a small pop out of the breather intake I read it could be ignition problem I have changed points and the other thing thats there what ever that is , coil is quite new is there a way to test the spark for strangth
john(UK)
11-18-2003 12:17:35
 Re: 2085 lacks power in reply to glen (ontario), 11-17-2003 15:06:10
Main jet should be open about 2.5 turns from closed and Air screw should be open about 1 1/4 turns. Then tune it from there. Set main jet on full throttle, air screw on Idle.
CH
11-18-2003 04:22:58
Ignition timing can cause that also.
old
11-17-2003 16:29:21
You may have your carb set a little to lean that can cause the pop and can also cause lack of power.
