12 volt conversion with a twist
Dale Johnson
12-06-2003 12:30:11
I've read several messages and all of the replies dealing with 12 volt conversions. None of them answer my question. I want to keep the look of the my TO-20. I have already changed my 6 volt generator to 12 volt (new fields). Do they make a 12 volt voltage regulator - positive ground? I seem to be having a hard time getting answers.
Duner Wi
12-06-2003 16:23:11
 Re: 12 volt conversion with a twist in reply to Dale Johnson, 12-06-2003 12:30:11
Take a look at a Neihoff #DR152T I think Delco #
1118779, fits an I-H 350 about 1958 thru 1961. It is 12 volt Pos. gr. Same reg. fits A-C J-D and Oliver about the same years. Good Luck!
Mr Chapp
12-06-2003 14:40:30
The answer is yes...there are many 12v pos ground systems available. The MGB auto is a good example.
Mr Chapp
12-07-2003 05:32:40
 Re: Re: 12 volt conversion with a twist in reply to Mr Chapp, 12-06-2003 14:40:30
Just an afterthought. I know that early Ford diesels used LUCAS generators. Not sure if they ewre origionally pos. ground, but it's easy to reverse polarity by arcing the b pos. and the field terminals on the regulator. Good luck & have fun!
Jim W
12-06-2003 15:03:47
The regulator is not polarity sensitive.
Jim W
tractorfix
12-06-2003 21:00:55
 Re: Re: Re: 12 volt conversion with a twist in reply to Jim W, 12-06-2003 15:03:47
Go to the scrapyard and get the one from a Dexta. They use 12 volt lucas stuff.
