to20 brake drum
nick
12-09-2003 10:29:22
removed right side (if looking forward) rear rim in order to fix flat tire. decided to check on brake shoe while at it. noticed two threaded holes in drum and decided they were for removing drum. used two bolts to drive drum out while gently tapping on drum with ball-peen.
two questions... are the holes in drum to be used in this manner, or are they for threading in a bolt then attaching a wheel puller? it looks as if i may have really stressed the threads (yes, i had backed of the shoes a bit so they weren't dragging on the drum.
what torque for putting rim back on?
thnaks.
nick
Randy
12-09-2003 14:51:26
 Re: to20 brake drum in reply to nick, 12-09-2003 10:29:22
Nick: Those holes originally had taper headed screws in them for holding the drum on to the hub. Don't pull on those holes. My MF35 has them too. I'm quite sure it's the same.
danct
12-09-2003 16:47:56
 Re: Re: to20 brake drum in reply to Randy, 12-09-2003 14:51:26
my to30 has the tapered screws holdind the drum also ,i dont think they are completely necessary i do know they are not to be used with a puller of any kind
Alvin n Ms.a
12-15-2003 06:07:01
 Re: Re: Re: to20 brake drum in reply to danct, 12-09-2003 16:47:56
They are non-essential, for normal tractor use, as the wheels holds the drums on. If you had a tractor blocked up, wheels off,(for I don't know what reason) then started the engine, decided to put her in gear, and rev. it up, then you would know why the kindly engineer was looking ahead. alvinnms
