.010 gasket material?
Jim W
12-16-2003 05:40:19
Does anyone know of a source for gasket materal that is exactly 0.010" thick? This is used between the axle trumpets and the differential housing, and has to be the right thickness to set the play in the differential bearings.
But please don't offer "try such and such a place" if you don't know that they have it. I have tried lots of places already and it is not a standard thickness; it is much thinner than usual gasket material. These gaskets are no longer available through my local MF dealer; they only have them for the later models which have a different diameter of axle trumpet.
I would also be happy to make my own out of something suitable if anyone has suggestions of 0.010" thick material. My cereal box is 0.020" so that won't work...
Thanks,
Jim
Nicolas Balikci
01-06-2004 06:38:22
 Re: .010 gasket material? in reply to Jim W, 12-16-2003 05:40:19
I found some .010 material at KINECOR in Montreal for my model engines. 514-333-7000 and they order it from GARLOCK PACKING AND SERAL, 866-458-7325. Good luck, Nick
capt kirk
12-17-2003 06:45:08
jim i dont think these will fit mine either. i know the 010 is suppose the set ring gear side play but with 50 plus years wear if i couldnt just use a silicone gasket maker and not put to much pressure against ring gear. it might actually compensate for this wear .i guess i will have to get it apart and see.let me know how u make out and if u actually find the correct part and where
marlowe
12-16-2003 17:20:49
i just got two last week and put them in a to-20 from my MF dealer they had to order them but they came in three days. i will look for the part no. if i still have the invoice. one more of them dealers that can't find shi-
capt kirk
12-16-2003 14:21:47
the gaskets are 15.25 in diameter. are these what we need ? they look a hair large.
Jim W
12-16-2003 19:15:48
 Re: Re: .010 gasket material? in reply to capt kirk, 12-16-2003 14:21:47
These might be for the later models. Mine need to be 14 3/4".
Jim
D.L.
12-16-2003 14:01:12
I'm not exactly sure what you're looking for, but we use brass and steel shim stock that is EXACTLY .010" thickness... could you use the brass stock & seal with gasket sealer??? Hope this helps!!!
Jim W
12-16-2003 19:18:11
 Re: Re: .010 gasket material? in reply to D.L., 12-16-2003 14:01:12
Yes this may be the answer. More of a pain to make I guess with all the bolt holes but at least I can get the right thickness.
Thanks,
Jim
capt kirk
12-16-2003 08:05:11
the gaskets are pre cut . i bought 3 to be safe .they only cost 1.50 each. im at work now i will measure when i get home and let you know .
capt kirk
12-16-2003 07:17:56
hey jim im getting ready to pull the trumpet on mine after doing my clutch i was given some at my dealer for to20 and told they would work .im not sure yet though. they measure 010. but they look like they have no compession if tightened.i wonder if a differant material would compress to 010 after torqued?my lower 3 pt arm is leaking on mine. after splitting tractor for a clutch not disengaging i found the pilot bearing froze up and turning input shaft to trans let me know how you make out my e mail is in your guest book
Jim W
12-16-2003 07:31:39
 Re: Re: .010 gasket material? in reply to capt kirk, 12-16-2003 07:17:56
Were you given the material, or the gaskets pre-cut? If pre-cut could you tell me their outside diameter? Thanks,
Jim
