Ferguson TE20 12 Volt Conversion / Sheet Metal
David Hooie
12-21-2003 15:14:50
Are there 12 volt conversion kits available for a Ferguson TE20? I have found conversion kits for TO30's, but it looks like the alternator mounting is not the same for a TO30 vs. a TE20. Also, I am looking for some grill parts for my TE20. Any information would be greatly appreciated.
Mr Chapp
12-23-2003 16:46:16
 Re: Ferguson TE20 12 Volt Conversion / Sheet Metal in reply to David Hooie, 12-21-2003 15:14:50
Again, nothing is cast in stone, but the Triumph TR4 is a very similar set up. They used a 12 v generator and regulator from LUCAS, "prince of darkness" all parts should be available through The Roadster Factory. You will however reference a Triumph TR4, instead of a tractor. Good luck, have fun and a Merry Christmas to you and yours!!!
john(UK)
12-23-2003 13:22:41
Sparex do Grilles for TE20...part Number S42914..see you local Sparex dealer
As Far as I can see no-one does a kit for converting a TE20 to 12v...but you can buy all the parts seperately that you would need.
John, IN
12-23-2003 05:10:40
Go to the link below for a 12 volt print. By doing it your self, you may be able to save enough to pay for your grill parts?
http://johnabillingsley.com/_wsn/page4.html
Paul in Ms
12-22-2003 03:46:46
Contact Dunlophydraulic.co.uk They will have all the grill parts for a te-20.I have a to-20 myself and I wish I could buy parts for mine. As for the 12 volt kit you could buy a kit for a to-30 and then make your own brackets. Everything else sould be the same.
wayne
02-07-2004 16:17:34
 Re: Re: Ferguson TE20 12 Volt Conversion / Sheet M in reply to Paul in Ms , 12-22-2003 03:46:46
Old 20 will have all the parts and any information that you will need,their postal service and help is second to none
