t0 20 rusty gas tank
Bob F.
12-31-2003 18:31:08
what is best way to clean out rust from tank? is replacement tank available.
Randy
01-06-2004 18:08:33
 Re: t0 20 rusty gas tank in reply to Bob F., 12-31-2003 18:31:08
Bob: I've heard and read that if you remove the tank and pour in a couple handfuls of drywall screws and then do something to swish them around in there, like roll it around somehow, all those little sharp edges will really scrape off the rust, and clean it real well. Then you could use the chemical reliner after it's good and clean.
Weekend Farmer
01-01-2004 21:39:38
I had that problem with my to-30. I took the tank off and cleaned as much rust out as possible with a pressure washer. After reinstalling the tank I unscrewed the sediment bowl and forced a short piece of copper tube into the inlet so that it sticks up about a inch above the bottom of the tank. This keeps the rust that settles on the bottom from going into the sediment bowl as fast. Worked for me - Occasionally I clean the sediment bowl of small amount of rust that gets over the top of the tube.
Frank (VA)
01-02-2004 17:53:01
 Re: Re: t0 20 rusty gas tank in reply to Weekend Farmer, 01-01-2004 21:39:38
I really am thinking about buying the chemicals to reline the tank. On the other hand, why can't I just put an in line fuel filter in so that I don't ruin the carb?
Frank
Paul F B
01-01-2004 11:51:02
Bob; There's a tank for sale on E-Bay, it's @ $35 with one day left. Paul
Paul F B
12-31-2003 21:48:33
Bob; Check out the link below. I used the product as directed and have had no rust prolems since. Check your local Massey-Ferguson dealer for replacement tanks. If you're from New York, I'll give you the name of an excellent dealer. Paul
