Vinegar
NCtim
01-05-2004 05:45:59
It seems that I remember someone hear saying that vinegar will remove rust. I've got some parts soaking in white vinegar and there doesn't seem to be any change. How long does this take.
Thanks.
jimbo
01-12-2004 23:07:39
 Re: Vinegar in reply to NCtim, 01-05-2004 05:45:59
I've had a lot of luck with acid based oven cleaner. Check the "Caution" info on the can. This stuff sprays a foamy mixture. Let it set awhile and wash off. Repeat as necessary. When using be sure to be up wind. Nasty stuff but works! I buy mine at a discount store for 99 cents a can.
David
01-08-2004 06:48:27
Sulphuric acid (battery acid) removes rust quite well but its dangerous to work with.
Dale in WV
01-06-2004 03:04:17
There's been previous postings about using Washing Soda and a Battery Charger to remove rust. I've recovered numerous tools ((yard sale rejects)) and brought them back to useful life using this system. And its cheap!!
NCtim
01-06-2004 05:19:40
 Re: Re: Vinegar in reply to Dale in WV, 01-06-2004 03:04:17
I'd like to know how this works, also.
rhouston
01-06-2004 06:33:26
 Re: Re: Re: Vinegar in reply to NCtim, 01-06-2004 05:19:40
search the archives for electrolysis especially on the tractor talk and JD forums. This process has been discussed at lenght. It does work very well.
Todd in Chrisney
01-06-2004 04:36:34
Could you explain this process . I heard about doing this several years ago and have forgotten about it, Thanks!
sam in mo
01-06-2004 06:40:36
 Re: Re: Re: Vinegar in reply to Todd in Chrisney, 01-06-2004 04:36:34
This should explain the process. attp://www.pacificsun.ca/~alsch/electrolyticrust.html
old
01-05-2004 10:46:21
Vinegar is good for flushing out the cooling system but not very good for rust removeal turpentine works good on rust
Paul F B
01-05-2004 08:50:59
It depends- is it apple or balsamic vinegar? I prefer PB Blaster myself. Paul
William
01-07-2004 18:28:58
 Re: Re: Vinegar in reply to Paul F B, 01-05-2004 08:50:59
P B Blaster... Greatest stuff every made... Almost.
Mr Chapp
01-07-2004 17:50:12
Vinegar is a de-limer.It removes calcium deposits...not rust.
