Question on Hydraulic Lift Cylinder
Bill
01-13-2004 20:31:35
While cleaning up the pump and lift on my TO-20.I decided to change the 3 ring piston to a NAA O-Ring type piston which is a 2 1/2" diameter wit 1 groove.Which required a NAA533A O-Ring,also required a backing washer #NAA473A.The backing washer fits in the same groove with the O-Ring and have a concaved side for the O-Ring to fit against.My question is which side of the groove do I install the backing washer against?The side of the groove closest to the pressure end or the side closest to the connecting rod .Thanks Bill
David
01-16-2004 10:27:35
 Re: Question on Hydraulic Lift Cylinder in reply to Bill, 01-13-2004 20:31:35
I think backup washers normally go on side away from pressure to support ring at the back.
