Ferguson TO-10 Parts
Michael Pezent
01-19-2004 18:52:47
Can someone answer a question for me? I'm looking for a sediment bowl for a 1947 Ferguson TO-10. Are there any available or can you use to TO-20 bowl instead?
Thanks!
Duner Wi
01-20-2004 18:16:21
 Re: Ferguson TO-10 Parts in reply to Michael Pezent, 01-19-2004 18:52:47
One possibility is you have a TO 20 serial #10 or the 10th on built. The serial plate under the dash only says TO followed by the serial # on the same line. If it is serial # 10 it is the lowest # I have heard of. Take good care of it.
Good luck!
William
01-20-2004 04:04:13
OK I'll bite. TO-10?
Mr Chapp
01-20-2004 18:01:51
 Re: Re: Ferguson TO-10 Parts in reply to William, 01-20-2004 04:04:13
Just guessing... take it to your local Ford dealer (tractor ) lay it on the counter, and say I need one of these. He will probably go to the back, and come out with the right part. Probably not a to10 or to80, but chances are good the parts will fit. Good luck, have fun....Look under the steering wheel for a small #plate. Use some lacquer thinner and .oooo steel wool to clean it off. This will let us know what kind of machine you have.
