front loaders
Nick uk
02-10-2004 09:56:51
Any body know of a loader that will fit a tea 20 (converted to Perkins P 3 ), that does not mount to the rear axle.
The reason being that I have a cab/safety cage fitted wich would have to be modified heavily to fit a horndraulic etc.
tractorfix
02-10-2004 13:46:52
 Re: front loaders in reply to Nick uk, 02-10-2004 09:56:51
Look for a picture of a Skyline loader. They mount to the bottom of the axle. Would this work?
nick uk
02-11-2004 03:49:59
 Re: Re: front loaders in reply to tractorfix, 02-10-2004 13:46:52
Afraid not, the front of the cab mounts just forward of the steering box, IE on top of the bellhousing is a beam that bolts to the front 4 bolts of the gearbox cover and the battery support studs. There is a cut out to allow the starter actuating rod enough movement(p3).
A modern high mounting point type might be ideal, IE nothing much comes behind the bellhousing.
