TO30 Special relief valve
51to30in MO
03-12-2004 11:47:37
I am in the process of setting up my dearborn loader on my Fergie and reading through the pappers on it there is a note to change out the relief valve to the "Special" relief valve. I have just put my pump back together and replaced the valve with (what I am sure is) the standard valve. Question is, what is the difference between the "Special" and standard?
Thanks to all!
Lee
todd
04-10-2004 06:56:17
 Re: TO30 Special relief valve in reply to 51to30in MO, 03-12-2004 11:47:37
lee tell us (me) more about adding a loader to your tractor. loader #, hydralic soruce, how does it work for you. thanks todd
Ray,IN
03-12-2004 19:32:56
I've never heard of a special valve. The standard valve is set to 2,200psi; perhaps the special is set even higher. Don't use a Ford relief valve, they are set to 1,700psi.
51TO30 in mo
03-12-2004 19:38:13
 Re: Re: TO30 Special relief valve in reply to Ray,IN, 03-12-2004 19:32:56
Ray,
I had not either until reading the info on the loader. They do look different the "Special" has the shank where the 11/16" wrench fits all the way to the end of the valve. I bought a replacement and it appears to be more like the original one in the picture?
Lee
