Finger Tip Control Lever (TO-20)
DaveinMo
04-15-2004 08:48:46
Just replaced my lift control lever shaft. Everything is fine except the control lever wants to spring up toward the top of the quadrant. It doesn't raise all the way up, just a few inches. But its enough to be a problem because I often have to hold my hand on the control lever to keep it in position. Should I just tighten the castelated nut on the control shaft a bit, or is there something more I should do?
Thanks in advance
Jim W
04-15-2004 17:17:49
 Re: Finger Tip Control Lever (TO-20) in reply to DaveinMo, 04-15-2004 08:48:46
Yes, that is the solution.
Ultimately you may want to get a new friction disc (I think they're rubber).
Jim
Jeff-oh
04-16-2004 05:48:12
 Re: Re: Finger Tip Control Lever (TO-20) in reply to Jim W, 04-15-2004 17:17:49
Jim,
The origionals were cork, then they went to rubber on later TO-20's and TO-30's. Then had problems and went back to cork. The replacement recommendation is to replace rubber with cork Friction discs.
Ray,IN
04-15-2004 22:19:15
The original friction material is cork. Tighten the aforesaid nut just enough to hold the lever in place after checking the cork for oil contamination and/or age deterioration. If the cork is oily or hardened replace it with new cork from an auto supply store.
