Older Hobbs meter and an oil pressure question
Tom H.
04-20-2004 08:34:25
I am in the process of restoring my 1954 TO 30 to its former glory. The tractor had all of its guages broken and I am looking for a source for an older clock style hobbs meter. I found a 1952 new in box one on ebay but was rapidly outbid for it.
Secondly, I had replaced my oil pressure guage with a new one that has a much smaller diameter flexible line on it. After I installed it there was no noticable pressure on the guage. I bled the pipe till oil started coming out the line and reistalled it. Still very liitle to no pressure. I removed the line from the block and I do get oil pumping out there. Should I try to get another guage with the original size line or rebuild the oil pump?
Thanks,
Tom H.
Jerry/MT
04-20-2004 12:20:54
 Re: Older Hobbs meter and an oil pressure questi in reply to Tom H., 04-20-2004 08:34:25
Tom, You don't need to bleed the air out the line supplying the oil pressure guage. It'll still read the virtually the same pressure with a air bubblwe in it Your engine is possibly worn and the clearances are opened up and the thus have a low pressure reading. The acceptable pressures for a TO-30 are 20 - 30 psi at 2200 rpm and 15 psi at idle.
It may be possible to that your oil pressure relief valve has a weak spring or is stuck open also. Hope this helps.
John, IN
04-20-2004 09:51:01
The line size will only reflect in volume, flow not pressure. Do make sure there is on sharp bends in line. Check The engine pressure at the block.
