TO-30 TILLER?
BRYAN
04-22-2004 19:44:52
I was thinking of buying a tiller for my TO-30. Never seen one used. Not sure how
well it will work behind this tractor? I was thinking it may be too fast.
Any past experience or advice would be great. Thank you
cdmn
04-24-2004 18:01:47
 Re: TO-30 TILLER? in reply to BRYAN, 04-22-2004 19:44:52
This makes me wonder: Has anyone tried to fit the later Ford planetary axles to the Ferguson or the earlier Fords for that matter. They have, I think, a 4.5 to 1 reduction. Should give real slow tillering speed. I might try it on my 3000. Off course top speed would only be about 5 mph. --cdmn
Chuck (CA)
04-22-2004 23:18:49
Hi Bryan,
In the past when this question was raised, it was the general consensus that unless you have a low range, it's just too fast like you thought.
Wayne
04-23-2004 18:59:12
 Re: Re: TO-30 TILLER? in reply to Chuck (CA), 04-22-2004 23:18:49
Bryan, just as Chuck has mentioned, I tried one on my TO-30 and found that 1st gear was too fast for it. I opted for a 2-bottom plow and a set of discs for my large garden area. That works very well for me. Have a good day.
WMS
BRYAN
04-23-2004 19:20:27
 Re: Re: Re: TO-30 TILLER? in reply to Wayne, 04-23-2004 18:59:12
Thank you both very much for your reply.
You helped me decide against the tiller.
I still think the TO-30 is a great tractor!
C.T.
04-27-2004 14:41:52
 Re: Re: Re: Re: TO-30 TILLER? in reply to BRYAN, 04-23-2004 19:20:27
Bryan
I have a 5 ft. tiller that i use behind my TO20.The tracor is a bit fast for the tiller.What i do is i take my 2 bottom plow and plow in the fall and till in the spring.The ground is fine as sand when done.Nice and level with no clumps like i use to get from discing.I also got a good buy on it,but i would have ended buying one eventually.I wouldn't take nothing for it as the ole saying goes.
