TEA Starting Problem
Peter( Ottawa)
05-15-2004 11:53:19
I'm attempting to start my 53 TEA for the first time. I engaged the starter 3 or 4 time at 30 seconds at a time the starter did'nt seem real strong but it was turning over. I tried again and nothing , I put the volt meter on the starter lug and measured 12v so that seems ok. I lightly hit the starter thinking I have a dead spot on the starter , still nothing. any ideas?????
Also I pulled the choke a few times and noticed gas coming out of carb, one guy told me that these Zenith carbs are real easy to flood, is this true??
I set the carb as follows top screw 1 1/2, bottom screw 2 full turns. New plugs ,gas filter, cleaned carb,etc...
Jim W
05-16-2004 06:10:40
 Re: TEA Starting Problem in reply to Peter( Ottawa), 05-15-2004 11:53:19
Hi Peter,
Yes they are prone to flooding. The needle valve that is closed by the float in the carb tends to not close too well. For this reason, always shut offthe fuel at the sediment bowl, otherwise, the entire contents of your gas tank can end up in your oil pan. Jim
Ken/MI
05-15-2004 13:24:29
Had the same problem with my TO-30 starter, Turned out to be a broken nose on the starter.
John, IN
05-15-2004 12:45:53
Sounds like you may have a loose connection.
Greg
05-16-2004 20:08:44
 Re: Re: TEA Starting Problem in reply to John, IN, 05-15-2004 12:45:53
I had a very similar problem with my TEA as it turns out it was the timing was off 90 degrees. I had recently rebuilt my tractor and it would turn over but wouldn't start. Good luck Greg
