Ferguson position control
Scott the Fergu
05-18-2004 10:12:04
Hi I have seen the Zane thing I feel this is not a practical set up when Ferguson has position control on it just that nobody uses it. Harry designed his tractor very well why do you think he put the long pin that goes through the three ears on the rear end. His haymower and Ferguson rear crane hook up on this pin and both have position control. I make these simple brackets that you can put a standard top link in use with a new style rear crane or put your brush cutter on and hold it at what ever height you want. You can leave it on the tractor and still use the factory toplink hook up for draft control. I will be making more of these have about 10 on hand now 55.00 plus shipping.
Mt Roy
05-19-2004 17:03:06
 Re: Ferguson position control in reply to Scott the Ferguson nut, 05-18-2004 10:12:04
Don't be so secretive. Post a picture and then see if you have any takers. Never know it might be worth 55 bucks and change.
