TE-20, TEA-20, or 2085: What is it?
Belleville Neil
05-23-2004 06:29:36
I just bought an old Fergie - its still in the field needing a new distributor cap and wires. The name plate is very hard to read but the stamped serial number is A157300. The plate says: Standard Motor co Ltd., Coventry England.
It has a Lucas starter(M4186 V139 1 6V), a Lucas distributor and a Delco-Remy(6C21 12V Neg)altenator(?) and a 12 volt battery. Hand written on the top of gas tank is M # 2085. The shift pattern on the transmission housing includes an "S" on the upper right but a keyed ignition has been added to the dash. What Model is this tractor?
Barry from Stirling
05-25-2004 06:17:10
 Re: TE-20, TEA-20, or 2085: What is it? in reply to Belleville Neil, 05-23-2004 06:29:36
Morning Neil
Barry from Stirling ( just north of you ) here. You have just what I have. Mine was that way when I bought here 3 years ago. The TSC Hardware store on Dundas St in Belleville is a good place to start. McKewon Motors in SpringBrook can get you anything you want.I have all the books on this old gal. Operators, Parts & Service Manuals. Your more than welcome to have a look at em. Give me a shout if you want to talk. Im at 969-3326 during working hours and 395-3438 after 6. Hoping to hear from you
Jim W
05-24-2004 07:15:59
They came with a keyed ignition switch originally. After turning the key to on, you then engaged the starter with the gearshift lever. That serial number indicates the earlier engine with 80 mm pistons, which you may find referred to as a TEA20-80 so as to distinguish it from the later TEA20-85.
For cap and wires try your local United Auto Parts. The one around here (Carleton Place) carries fast moving parts such as these for the Fergies. For spark plugs you can use NGK B6HS.
Jim
NCtim
05-23-2004 07:21:03
It's a TEA-20. Someone has converted it to 12 volts.
Is this Belleville in Illinois?
Belleville Neil
05-23-2004 07:50:12
 Re: Re: TE-20, TEA-20, or 2085: What is it? in reply to NCtim, 05-23-2004 07:21:03
Does an alternator tell me if they made an informed (complete)conversion? I'm concerned they may have just stuck a 12 volt battery into the tractor. The coil doesn't appear to have any details or name on it so I can't tell if it is 6 or 12 volt. The starter appears to be 6 volt - does that matter on a 12 volt system?
I'm in Belleville Ontario.
Jim W
05-24-2004 07:03:29
 Re: Re: Re: TE-20, TEA-20, or 2085: What is it? in reply to Belleville Neil, 05-23-2004 07:50:12
If it's still a Lucas coil it will have numbers stamped on the bottom identifying whether it's 6 or 12 volt.
Jim
NCtim
05-24-2004 05:51:57
An alternator means it's 12 volts. The starter doesn't care much if it's 12 or 6. Be careful not to overheat it. Your distributor and coil are probably still 6v as well.
