Ferguson TE20 Engine Torques
David K
05-26-2004 05:52:09
Does anyone know the correct torque for crankshaft, big end bearing caps, and cylinder head bolts, for 1954 TE20 4 cyl. diesel.
Thanks, David
Burt
05-26-2004 12:51:38
 Re: Ferguson TE20 Engine Torques in reply to David K, 05-26-2004 05:52:09
Cylinder Head Nuts 75 to 80 lbs ft
Big End Nuts 65 to 70 lbs ft
Oil Pump Attatchment 16 to 18 lbs ft
Flywheel Set Screws 90 to 100 lbs ft
Main Bearing Socket Screws 25 to 30 lbs ft
Centre Bearing Housing to Block 39 to 42 lbs ft
Clutch Fixing Screws 26 to 28 lbs ft
Injector Attatchment 12 to 14 lbs ft
These are for Standard Diesel Engine taken from Ferguson System Workshop Manual hope they are of help to you. Burt.
David K
05-28-2004 15:05:14
 Re: Re: Ferguson TE20 Engine Torques in reply to Burt, 05-26-2004 12:51:38
Thanks Burt, thats a great help
