My solution to getting stuck Bushhogging
Paul (FLA)
06-07-2004 09:31:25
I do some extreme bush-hogging, and I always get stuck. My rear wheels go into a ditch, and the hog hangs up on the ground. Then I have no traction.
My solution: when I get stuck, replace the top link of the 3 point with a come-along, and crank the hog up off the ground, and then drive out. Then lower the hog, and replace the 3 point link.
Seems pretty simple, but took me a while to figure it out. Hope this helps somebody out there.
Paul
Boss Hog
06-10-2004 06:21:51
 Re: My solution to getting stuck Bushhogging in reply to Paul (FLA), 06-07-2004 09:31:25
I've done something similar, but not with a come-along.
I remove the top link, then get out my log chain. (Always carry one)
I drop the 3 point arms down as far as they'll go. Then I loop the chain under both pins where the top link was, and shorten it up as tight as I can. This in effect makes a very short top link.
Ya gota be careful to NOT flip the tractor over backwards when you don't have a solid top link. That's a good way to get yourself killed.
James, UK
06-08-2004 09:21:21
Hmmm, Xtreme Bush Hogging - is that some kind of new sport you guys have over there (j/k).
Seriously, like others have said, I prefer not to get stuck - but have still managed to do so in some unlikely places. Nuff said.
Barry from Stirling
06-07-2004 10:49:18
Afternoon Paul
I think it would be better if you didnt get stuck at all,much safer. I will note your solution to get out. Thanks Barry
Mike G. in NB, Canada
06-07-2004 13:00:17
 Re: Re: My solution to getting stuck Bushhogging in reply to Barry from Stirling, 06-07-2004 10:49:18
I learned a long time ago, as a farm kid, to avoid getting tractors stuck. You develop kind of a sense after a while as to what your machine can and cannot handle.
I'll never forget having the Case Agri-King 970 stuck halfway up the rear axles with a 15 foot disc harrow behind it. We got it out by unhooking the harrow and pulling with a smaller 4WD tractor. :-)
-mike
Paul (FLA)
06-08-2004 11:46:49
 Re: Re: Re: My solution to getting stuck Bushhoggi in reply to Mike G. in NB, Canada, 06-07-2004 13:00:17
Not getting stuck is preferable.
What was I thinking.
The problem is, with the bucket in front, and not being able to see the ground contour due to the blasted Palmettos, it does happen more than I care to admit.
Paul
06-09-2004 07:12:20
 Re: Re: Re: Re: My solution to getting stuck Bushh in reply to Paul (FLA), 06-08-2004 11:46:49
I always found that loaders are the worst thing to have on a tractor when you're doing field work. You can't see where you're going and they have to be kept low so you don't roll over the tractor. Probably the best intermediate solution is to remove the bucket so you can see a little more.
-mike
