Hydraulic control valve
Jim
06-27-2004 11:20:09
Have just completed a rebuild of the hydraulic pump on my T20 but have fogoton which way the control valve should be installed! The stem that conects the valve to the forks has two little "bumps" on it, should these "bumps" face up or down. Hopefully someone will know what I'am on about!
Cheers, Jim
Robert R
06-30-2004 18:30:24
 Re: Hydraulic control valve in reply to Jim, 06-27-2004 11:20:09
I installed mine bumps up, watching a vidio that took me through step by step. really do not think it matters as long as you get the T of the spool snaped into the fork properly. Hopefully you installed the new style main lift piston and valve spring under an 8N ford part #.
marlowe
06-27-2004 15:21:37
it don't make any difference the little ears only keep the little thing in the center of the fork
