Pressure relief valve
Belleville Neil
07-09-2004 16:52:23
My hydraulic pump is sitting in the drip pan out in the driveway. I have a cracked right hand chamber assembly, a bent valve stem and a grooved up pressure control valve body. I was able to buy a new pressure control valve, actually bought two from different sources, but neither valve body seems to fit the valve drive assembly very well. I did some filing and grinding and now have the parts back together. Has anyone else had this problem? Are all right hand chamber assemblies interchangable?
Ray,IN
07-09-2004 20:35:01
 Re: Pressure relief valve in reply to Belleville Neil, 07-09-2004 16:52:23
Assuming you have a TO20, TO30, TO35; the hyd pump is the same I believe. Parts are available from davistractor.com to rebuild your pump if the supporters listed under marketplace cannot supply them.
Belleville Neil
07-09-2004 20:40:59
 Re: Re: Pressure relief valve in reply to Ray,IN, 07-09-2004 20:35:01
The tractor is a TEA-20, but I think the same pump is in the Fords and up into the Fergie 30's.
John (UK)
07-11-2004 09:39:36
 Re: Re: Re: Pressure relief valve in reply to Belleville Neil, 07-09-2004 20:40:59
There are two types of side chambers. one uses gaskets and the later type uses "O" rings. all the same type of chamber will interchange and some left and right will interchange as well. Sparex part number S61319 if you need it, but you may be able to find a used one. The gasket for the chamber is Sparex S61321 or MF 181087M91. They changed to "O" rings at serial #330043 (1953)
