down pressure on front end loader on my TO30
barney
07-12-2004 15:07:25
I have a lord loader on my TO30 and it has down pressure,but the down pressure is losing its strength,it use to pick the front end of tractor up off the ground easily,now it doesn't seem to do it as well,it still has pressure but doesn't seem to be as good as it use to be.what causes this?thanks for any help.
John (UK)
07-13-2004 10:59:43
 Re: down pressure on front end loader on my TO30 in reply to barney, 07-12-2004 15:07:25
Most likely the relief valve is worn with continually discharging, but you could also have a leak. You need to check the pressure on the system, it should be 2200psi but it will be down from that with wear and tear...as long as you can get about 1800psi. min should be ok. if you need to find the leak mail me for a help sheet on what and where to look.
