I spoke too soon re pto leak
Mr Chapp
07-12-2004 18:22:52
Hi all...In my last post I said I'd never had a problem, so, I'd never checked my hydraulic oil...well...Now I have a steady drip from the pto seaal. From memory, I remove the orc, drain the fluid, remove the bolts around the shaft, and then..isn't there a circlip? Now I should be able to remove the seal. Am I right? All suggestions will be greatly appreciated. Thanks in advance, Mike
Mr Chapp
07-13-2004 11:37:57
 Re: I spoke too soon re pto leak in reply to Mr Chapp, 07-12-2004 18:22:52
Again...Thanks for your help. Mike
Ray,IN
07-12-2004 20:29:09
If you have the modernized PTO shaft with the 1 3/8" splines you will have to remove the shaft, press off the bearing to change the seal. If you have the 1 1/8" splines you are correct.
Jim W
07-13-2004 04:38:50
 Re: Re: I spoke too soon re pto leak in reply to Ray,IN, 07-12-2004 20:29:09
Here is a page on this. When I did this operation I found that some shafts had a circlip at the rear holding in the oil seal, but others didn't (and didn't have a place for one). The two inner circlips that fit in the housing are what keep the entire shaft located (via the bearing).
Anyway the easy thing to do is draw out the assembly and work on it on the bench.
Jim
