12volt conversion wiring
GaryH/OH
07-30-2004 13:48:50
Does anyone know how the wiring is suppose to be
ran on a 1954 Ferguson 1 wire alt. system.I,m changing from 6volt to 12volt.I,ve removed 6volt
voltage reg.One wire went to one side of amp gauge
and the other went to the key switch.Tractor cranks but will not fire.
maggs
08-04-2004 17:59:41
 Re: 12volt conversion wiring in reply to GaryH/OH, 07-30-2004 13:48:50
I am searching for a conversion wiring diagrram for a Harry Ferguson TE-20 Six volt to twelve volt, using a delco alternator with a built in voltage regulator. Any help with this will be deeply appreciated. Thanks
John (UK)
08-05-2004 12:36:29
 Re: 12volt conversion wiring in reply to maggs, 08-04-2004 17:59:41
Try here Link
GaryH/Oh
08-09-2004 15:55:07
 Re: 12volt conversion wiring in reply to John (UK), 08-05-2004 12:36:29
Thanks John(UK)I got my TO-30 running after i did
the 12volt conversion but my temp. gauge will not
work. Any ideals. Thanks Gary
John (UK)
08-10-2004 11:35:43
 Re: 12volt conversion wiring in reply to GaryH/Oh, 08-09-2004 15:55:07
Gary, You dont say if you are using an electric temp gauge or the original type. If its the original type really the only way is to change it, if the water is getting hot and you are not getting a reading it must be the gauge unit, there will be a leak in the tube somewhere vibration cracks it. If its an electrical one you could just try replacing the sender unit, thats the bit that goes into the engine, that is the part to go normally...John
John (UK)
07-31-2004 06:53:03
I do have a wiring diagram for a conversion like you are doing, using a single wire alternator. If you would like a copy mail me at fergusontractors at hotmail dot com add your original mail to it so I dont have to search through all my mail though please.
