TO20 puller
nelson
08-01-2004 08:30:01
Wanting to know of a way to get more power from my TO20.Compression is good , so I won't change pistons. What about different; head, manifold, carb,distributer,? Valve clearance adjustment? Anything to give it more power. We pull with a three M.P.H. speed limit.
youngster
08-02-2004 07:25:56
 Re: TO20 puller in reply to nelson, 08-01-2004 08:30:01
you might try turnin up the card so it runs roughat idle with no load but under load straighens out. there is just too much fuel goin throiugh at idle and under load it will use the fuel. if you really want to get into it rejet the carb.
nelson
08-03-2004 04:39:43
 Re: TO20 puller in reply to youngster, 08-02-2004 07:25:56
rejetting the carb sounds like an idea to try. Can you give me some direction as for as finding other jets? Possibly a TO30 carb has bigger jets. I have heard of enlarging the jet with a drill too.
youngster
08-03-2004 08:26:57
 Re: TO20 puller in reply to nelson, 08-03-2004 04:39:43
i dont know how to do it yoiu might try lookin for to-30 or might even get a gas 50 carb and put it on i know a 50 uses alot more gas then a 20
marlowe
08-01-2004 17:33:39
i pull a to-20 in 2750 or 3000 and only thing i did is i have a 3 speed sherman trans. got 3rd on sat in 3000 out of 8 on dirt but on black top it dose a lot better
nelson
08-01-2004 18:14:00
 Re: TO20 puller in reply to marlowe, 08-01-2004 17:33:39
A Sherman step down would probably help me too. I was just wandering if there was anything i could do to the engine. On a hard dirt track the tractor runs out of power before spinning the wheels.
marlowe
08-01-2004 20:18:03
 Re: TO20 puller in reply to nelson, 08-01-2004 18:14:00
the huppt or sherman is the way to go i have never run out of power in low low and on sat it was a hard pulling track but on black top i pull in 2or 3 low
