3PH Hydraulics: TEA 20
Jere
08-04-2004 23:31:58
The hydraulics on my TEA 20 Ser.# 193649 do not work at all. Moving the lever up and down, even without an implement, does nothing. I pulled the dipstick and checked the oil, and it is clear . . . no milky or cloudy appearance. Does anyone have any suggestions of what I should do next? I have a fairly comprehensive manual that I bought from this site, but I don't want to tear in too deep if there are simple things to try first
Thanks
Jere
toolman
08-05-2004 10:43:15
 Re: 3PH Hydraulics: TEA 20 in reply to Jere, 08-04-2004 23:31:58
is the lever working, mine broke one winter and i though at first it was something worst until i noticed that it wasn,t moving anything.
jere
08-05-2004 11:20:40
 Re: 3PH Hydraulics: TEA 20 in reply to toolman, 08-05-2004 10:43:15
If it is broken, it must be inside the casing. The entire shaft seems to be rotating alright. The threaded part sticking out moves with the lever, so the lever is not just rotating on a stationary shaft or anything.
toolman
08-06-2004 14:05:19
 Re: 3PH Hydraulics: TEA 20 in reply to jere, 08-05-2004 11:20:40
i have seen one where , the oil had not been changed in years and had alot of moisture in it , well when it got real cold in the winter , it must of frooze or something and he forced it and snapped the lever right at the rotating point, went the whole winter with it BROKE, i checked it for him in the summer and found the broken lever.
John (UK)
08-05-2004 10:25:09
If you are sure that the PTO is in gear, most likely cause is the control valve has stuck for some reason. if you email me at fergusontractors at hotmail dot com I can send you data sheet on what to check for this problem and more if you need it.
Jim W
08-05-2004 05:05:44
Is your pto turning?
Jim
