TEA 20 pinch bolt - Pulley Hub
Belleville Neil
08-05-2004 20:41:58
How does the pinch bolt work on the water pump pulley hub? I took both my old pump and my new pump to the dealer to have the pulley hub pulled off the old pump and pressed onto the new pump. When I went to replace the fan pully, it wouldn"t fit until I loosened the pinch bolt nut and tapped the pinch bolt to the point of protruding equally on both bolt and nut sides. Will that be OK? Your thoughts please!
John (UK)
08-06-2004 10:54:50
 Re: TEA 20 pinch bolt - Pulley Hub in reply to Belleville Neil, 08-05-2004 20:41:58
Is it the original setscew in there? Sounds from what you say its too long. It shouldn't come off because its in the groove in the shaft but it should tighten it up.
