TO 30 Front Axle
Billiam
08-06-2004 11:28:01
I recently bought a "53 TO 30. It"s in great mechanical shape and seems completely original except for the front axle assembly, and I"m hoping someone out there can help me identify it. It appears to be from a newer Ferguson, and looks like it originally was painted silver with red hubs. The big clue is that the spindles appear to be a "quick-grease" type with grease fittings on the ends of the spindles, serviced through holes in the dust caps. Could the axle assembly be from a newer model, say a TO 35, or maybe a TO 30 option or even a standard feature toward the end of the run? Thanks for your help!
Paul in Ms
08-08-2004 05:04:38
 Re: TO 30 Front Axle in reply to Billiam, 08-06-2004 11:28:01
My 1950 to-20 came from the factory with the same grease fittings. They are recessed in the dust caps . I have broke one of them off but was a easy fix. I try to grease every time I use my tractor.
Billiam
08-08-2004 10:49:54
 Re: TO 30 Front Axle in reply to Paul in Ms, 08-08-2004 05:04:38
Paul in Ms:
Thanks for your reply. If it is a factory feature I"ll feel better about it. I"ve still got to take one apart to see what"s up.
Fred OH
08-07-2004 09:06:08
I'd say it is the standard front end that someone has drilled and tapped the dust covers for a zerk fitting cause he run through a waterhole occasionally. See if theres any casting numbers on it and post back. Can't think of any reason to change front ends unless you went to a heavy duty one for a front end loader or power steering. Looks like the zerks would be kinda easy to tear off out there on the end of the spindle...then you'd have a bearing full of dust or worse. This is my guess. Fred OH
Billiam
08-07-2004 22:00:13
 Re: TO 30 Front Axle in reply to Fred OH, 08-07-2004 09:06:08
Fred OH,
Thanks for your reply. Your opinion seems very reasonable to me. My assortment of manuals just arrived today so I"ll look through them to become a little better informed. Also I"ll jot down the casting numbers for you and pop the dust caps off to get a better look at things before I post back. It may be a few days but I"ll get it done. Thanks again.
