Ferguson Manure loader
Belleville Neil
08-14-2004 19:53:48
MY TEA 20 has been plumbed for a Ferguson front end manure loader. I have a piston mounted under my quadrant lever that is activated by the finger tip control lever. A hose comes up from the bottom of the pump and connects to this piston affair. The bypass seems to through the inspection port cover on the right hand side. Does anyone else have this setup or have details of which connections do what?
Neil
Jeff-oh
08-16-2004 06:34:21
 Re: Ferguson Manure loader in reply to Belleville Neil, 08-14-2004 19:53:48
The by-pass set up is similar to the L UO 20 loader set up. Do you have the loader itself? I have a L UO 20 I need to let go cheap.
Jeff
Brent, IN
08-16-2004 08:12:33
 Re: Ferguson Manure loader in reply to Jeff-oh, 08-16-2004 06:34:21
Might be interested in the loader. Can you give me condition on it or send me pictures?
Jeff-oh
08-16-2004 12:01:27
 Re: Ferguson Manure loader in reply to Brent, IN, 08-16-2004 08:12:33
Loader is not complete. It it the 2 hydraulic piston arms the Blade, and Spikes, support arms. However, I do not have the attachment brackets or dump control. That is why it is very inexpensive.
Jeff
Rob in VA (Fluvana)
08-17-2004 07:41:19
 Re: Ferguson Manure loader in reply to Jeff-oh, 08-16-2004 12:01:27
HI Jeff. How do email you for info?
John (UK)
08-15-2004 13:47:51
Neill, What type of Ferguson loader have you got? They used something similar to that set up on the High-Lift loader in UK but I didnt think it ever made it over to the US. The High-Lift Loader is banana shaped and attaches to the tractor at the rear of the drivers seat and arches forward to the front of the tractor over the front axle, it has a hydraulically operated bucket and fork and this arrangement was to tip the bucket.
Belleville Neil
08-18-2004 07:45:33
 Re: Ferguson Manure loader in reply to John (UK), 08-15-2004 13:47:51
I'm not sure of the model but it is not the banana type. There is a picture of it on pg 80 of Gibbard's The Ferguson Tractor Story. There are connection points on the front axle and under the rear axle. Thanks to Al in BC, I see that the valve is in my parts manual as a Hydralic Valve (TO 30). It is still unclear to me which connection on that valve is the pressure in from the pump and which is out to the implement. Any thoughts?
