Sherman trans for a Fergie?
PD
08-22-2004 20:37:36
I just wondered if there was a Sherman auxilliary transmission available for my old TO-20 like what is used in Ford N-Series tractors. Sure would be nice to have lower gearing for tractor pulls. Thanks and regards..... ..... .P
txblu
08-26-2004 09:32:57
 Re: Sherman trans for a Fergie? in reply to PD, 08-22-2004 20:37:36
You"d hafta add a Rolling FFFFF FFFord shield to the tin if you did....Fergie would roll over in his grave.
Mark
Bob F.
08-23-2004 04:54:09
We've got one on our TO-20. Grandpa bought it that way when it was new. I did see one on E-Bay a while back that came off a Ford 8N or 9N. I did some checking as it looked just like ours. I wanted to see if it would fit our TO-30. I later found out that it would not fit a Ferguson so apparently if you find one, make sure it did come off a Fergy.
Bob F.
Mikepa
08-22-2004 21:52:27
Sherman's are out there, problem is finding them. You can also look for a Hupp trans. About the same as the Sherman but shift lever is on right side. Have a Hupp up & down on my TO30, works fine with 12 fwrd spds but usually just use lower range.
